hay or beans again
Rich Iowa
09-09-2005 19:38:21
I had another thought today. What if I plowed under my hay field and drilled a pure grass mixture. Would that work, or should I just plant soybeans next year? I got my soil in today for a soil test, be a couple weeks to find out what I need.
My field is presently a mixture, 30-40% alfalfa, and 60% grass mixture, Smooth Brome, a bit of orchard, and very little red clover. There is one type of grass I can"t identify; it"s about 3" tall, grows in a cluster, long narrow leaves alternate sides, has purple seed heads, alot of leaves at the base where the stem is oval shaped, and has a waxy coating on the whole plant. Can someone help me with this ID? Another question, what"s the differance between Warm and Cool season grasses? I can"t figure it out. I did noticed the bromegrass bunches have produced much in the last half of the summer, does it have something to do with the heat? Thanks for all the help, and opinions. Rich
rambler
09-09-2005 23:33:42
 Re: hay or beans again in reply to Rich Iowa, 09-09-2005 19:38:21
Sounds like you have a nice field now, why start over & lower the legume content? Will folks pay more for all grass? Where I live, 'ditch hay' brings 50 cents a bale, while alfalfa can go around $2 if good. Mixed is somewhere in between. So where I am, you would be downgrading. Do you have a market for pure hay where you are?
--->Paul
kyhayman
09-09-2005 22:19:12
Not sure from the sescription but the 'purple grass' could be fall panicum. An invasive perennial grass which has moderately high food value and moderately low palatability. Warm season grasses thrive (grow, bloom, set seed), as the name implies during warm temperatures (seems as I recall 80 degrees or so is when they emerge). Cool season grasses emerge with spring warm up and decline during the heat of the summer. Then produce again in the fall, with the onset of cooler nights triggers the crowns to spread (hence the brome grass green up). Most, but not all warm season grasses produce higher yields due to using C4 photsynthesis (corn, sorghums, etc are all warm season grasses). Cool season grasses to my knowledge all use C3 photosynthesis, the same as broadleaf plants.
As far as what to do with the field, my question is 'why'? That sounds like a marketable hay field now. Pure grass may be too but at todays nitrogen costs that adds a lot to getting equal yields. Soybeans are ok, can make some decent money but if I recall they lokoked iffy to you on economics. Alfalfa if you want to can be selectively removed with 2,4-D or Banvel. I think that the field as it is now should give you upwards of 200 square bales per acre, at $2 a bale thats $400. Even assuming a harvest cost of $150 and a fertilizer cost of $80 an acre this is still clearing well over $150 an acre, even at a bargain price of $2 a bale.
Rich Iowa
09-10-2005 04:45:12
 Re: hay or beans again in reply to kyhayman, 09-09-2005 22:19:12
Thanks Kyhayman, that"s why I post my ideas, somedody allyway sees something in my plans that I didn"t see. The alfalfa didn"t do much this year. The 2nd cutting, the alfalfa grew only 8-10" before it started blooming, this third cutting is about the same. I suppose some fertilizer and lime would help a lot. Would I be right in thinking it would be best to have a mixture of cool and warm season grasses in the mix? Might also explain why the yield drops in the late summer for me.
I also have some misc. weeds in the field, mostly broadleaves, some grasses too, like foxtails. What would you recommend for that? Now I"m thinking of waiting another year and see what the fert. does for me, thanks again.
kyhayman
09-10-2005 05:31:33
 Re: hay or beans again in reply to Rich Iowa, 09-10-2005 04:45:12
'As a rule' mixing cool and warm season perennial grasses is a bad idea. One or the other tends to choke the other one out as their growing seasons overlap. The orchard and brome blades are where the real advantage is to mixing with the alfalfa. The first cutting should give you about 40-50% of your total yield on a mixed stand. This would be your high volume lower value cutting (I typically get 100-120 squares per acre off of it). Next 3-4 should run 30 or so each. As alfalfa thickness declines, I strtch my harvest intervals from 30 to harvesting at 45 days and the yield runs around 30-40 bales per acre. These are under 'textbook' lime and fertilizer applications.
I soil test every year on alfalfa and lime/fertilize in the fall to soil test. Plus I hit it again after the first (hay) cutting with 100# DAP (18-46-0) and 200# muriate of potash (0-0-60) per acre. My soils test naturally pretty high in phosphate so rarely does the test call for any in the fall. Usually have to put on a big dose of K in the fall which helps avoid winter kill (typically my fall soil test calls for 300-400# of muriate per acre plus a little boron). Alfalfa is a huge consumer of potassium (potash), something like 300# K per acre under normal yields.
Best cure for foxtail and other warm season weeds is a mower. Most of them cant stand a 30-40 day mowing schedule.
Blooming at 10" tells me something is going on with the tap root. First thought is a water or nutrient problem at about 20". Droughty conditions and an acid subsoil can limit growth like this. That describes my third cutting this year, it had to grow without any rain at all. Yields took a hit, down about 18 bales per acre on some. Looking like real compensatory yields on 4 and 5 with 5" of water from Katrina.
Rich Iowa
09-10-2005 14:32:58
 Re: hay or beans again in reply to kyhayman, 09-10-2005 05:31:33
My hayfield is at the top of a hill and is mostly clay soil. The soil does have some good cracks in it as it has dried out. It way pretty dry during early-mid summer. I"ll have to wait for my soil test to get back to see what I need to do. Thanks for all the help, Rich
