Oliver 3 bottom pull-type plow paint scheme
JD farmboy
09-08-2005 18:35:41
My dad has an Oliver 3 bottom pull type plow that we are in the process of restoring and we're not sure what the paint scheme is supposed to be or where there should be decals or what the decals should look like. I'm not sure what the model is but the rear of the moldboards had Oliver Raydex painted on them, it has three wheels and has a cylinder lift system, the rear wheel runs at an angle and the plow has a lever to adjust it with, it is pulled with a clevis and has a trip release at the clevis so when you hit a rock it just breaks away from the tractor. If anyone knows what model this is or if they have any information on it or if anyone knows what the paint scheme is supposed to be it would be a big help. TIA, JD Farmboy
Randy-IA
09-09-2005 17:23:27
 Re: Oliver 3 bottom pull-type plow paint scheme in reply to JD farmboy, 09-08-2005 18:35:41
Hi , You may be able to get some of that info from the Floyd County Museum in Charles City , IA . I included the link to them below but if it doesn't come thru here is the phone # (641) 228-1099 . It might take some digging to find out your model # . Be patient and they will help all they can . Good luck . ...Randy
