NH Super 66
Vince H
09-08-2005 05:58:41
I am going to be looking at a NH Super 66 baler this weekend. Is there anythng that is common with these balers to check for. Is there anything I should look for with the knotters and the chains and other parts?
screaminghollow
09-09-2005 07:36:47
 Re: NH Super 66 in reply to Vince H, 09-08-2005 05:58:41
can"t say much. My buddy has two of them he still uses and he makes a few thousand bales each summer. Check all the rotating parts to see if they"ve been greased regularly and aren"t too loose., make sure the needles are ok.
I found with my old Super 78 Hayliner ($100.00 two years ago) that it won"t work with the thinner twine, but works great with the thick twine. I put just under a thousand bales in the barn this year with it, and figure I got my money out of it. And anything from here on out is just a blessing. When I last baled, I had only one bale out of 275 that didn"t knot. My baler was kept under cover (only a little rust) and was painted at least twice. So I figure that was an indication that the prior owner(s) cared for their equipment.
Last Monday at a farm auction near here an otherwise really nice new idea baler only brought $27.50, needed two new needles, both broke. The machine looked brand spanking new otherwise. I had no knowledge of how available the needles are so I stayed away from bidding. Another neighbor still uses a NH 66 and he paid $250 for his six yrs ago. He is hard on equipment and has had to weld and piece things together dozens of times. He even broke an axle off, now how he did that...????? ?
Steve from New Holland
09-09-2005 04:20:36
Boy, I would like to encourage you to look at something a tad newer. Not too many guys left that know much about these balers. I have worked on New Holland balers going on 29 years and my knowledge is very limited. If you buy one, do not give much for it. Steve
Brokenwrench
09-08-2005 11:05:23
Hey Vince,
There`s some on here that will probably have better info than me, but I`ll give you my 2 cents.
They`re a good old baler, small capacity though.
Check the wooden wad board, and plunger. The knotters you can give alittle inspection, if anything is loose(pinions, billhook, etc) might be a sign that the thing will probably not tie decent. You should also be able to see if it`s been greased regularly by looking at all the greasable components. You didn`t state price or condition of the baler. Be careful not to pay too much, these are old machines. If your gonna run a fair amount of hay, I`d look more toward the 67, 68 or JD 14 or 24T. Hope this helps Brokenwrench
Chick
09-10-2005 09:43:05
 Re: NH Super 66 in reply to Brokenwrench, 09-08-2005 11:05:23
The age is not as important as how well it has been taken care of, but heed what Steve said, and do not give much for it. Most of the knotter parts are probably still available. I finally gave up on my NH 69, as there were too many things wrong. It finally started breaking the chain to the feeder tines. Probably something getting in a bind, but I didn't even look. If anyone needs some galvinized sheet metel feeder tray or the back cover of the feeder tines, I would let these go resonable. I had them made at a sheetmetal shop 5 years ago, and they will never rust.
