bale weight from JD baler
mlm
09-07-2005 21:12:45
I have been told 4x6 hay bales from a JD baler can weight 2500 pounds. they have a final weight of 2000 pounds after setting/drying. If baled just so, the hay ferments some without mold and cattle really like this kind of hay. can this be true?
Matt Minacci
09-08-2005 15:16:17
 Re: bale weight from JD baler in reply to mlm, 09-07-2005 21:12:45
I can't tell if the hay ferments or not but I can say that I have been baling with a JD 430 round baler going on 10 years now and the manual states that a 4X6 bale is about 1400lbs. I bale orchard grass to feed to my Angus. The baler is very sensitive to moisture and the grass will build up on the rollers if levels are too high. Now newer bales equiped with scrapers my fair better. As to what cattle like, I have been around them for 30 plus years and when they are hungry they will eat most any hay. I have not had the protein levels of my orchard grass tested, but in the middle of winter with snow covered pasture their manure is still very runny. It is much like that of dairy cattle, which generally get feed products with high protein contents. Just my 2 cents. Matt
Tx Jim
09-08-2005 04:01:40
I think that JD doesn't advertize a 4X6 rd. bale weighing 2500#'s. Alfalfa bales will weigh more than grass bales with same hyd. pressure. 20% moisture hay is approaching mold/mildew. I also think that if bale had that much moisture to weigh that much it would mold if not put in haylage bag. Tx Jim
txgrn
09-14-2005 06:28:13
 Re: bale weight from JD baler in reply to Tx Jim, 09-08-2005 04:01:40
Agreed.
About cow preferences. I can't believe what cows choose to eat. Totally mindboggling. Seems the worst stuff is what they prefer.
Recent case in point. I bought a new to me used baler. Expected it to be ready to bale. Not so. Had rain on the way and baled abnormally large bales. Butted them end to end. Hay was too green/wet and the things would have caught on fire, had they had access to oxygen.
The center was burned to a crisp; just crumbled in your hand. The outer half was real nice as it didn't overheat.
Set the bales out and you guessed it. They ate the burned part first. Beats me.
Had a neighbor with an erosion problem. Had some hay rolls that were like 5 years old. Dumped them in the gully. The pasture was in good shape so the cows weren't hungry from lack of provisions.
Came back sometime later (week or so) and only thing left was scraps and twine.
Mark
