Anyone with a Bushhog 286 cutter
tomttomtom
09-07-2005 10:21:44
Hey,
I picked up a 286 used the other day for $500.00. It was in to good a shape to pass up so I bought it. The tail wheel is in bad shape though. It needs a bearing kit bad. The caster fork shaft is very loose inside the tailwheel frame. Is this common wear and tear? I can't decide if it's the tailwheel or the frame that needs to be replaced! Does anyone have the diminsions for this cutter?
Thanks,
Thomas
Rod in Smiths Falls, ON,
09-07-2005 14:33:53
 Re: Anyone with a Bushhog 286 cutter in reply to tomttomtom, 09-07-2005 10:21:44
Have you tried using it the way it is? Chances are it will work fine.
