HayDr. ??
Loren
09-05-2005 18:48:06
On drum mowers. I checked a website for an outfit making them, can't remember which at the moment, and saw that the hp requirement/foot of cut seems to be less than a disc job. Correct? What I can't figure out is why are they so narrow? If I had the dough I'd be tempted to get a bigger one than what I see unless there's a problem going there. Since I can't travel fast on the rough fields I would need to make up the production with width. Loren.
Hay Dr
09-07-2005 04:16:59
 Re: HayDr. ?? in reply to Loren, 09-05-2005 18:48:06
The CCM drum mowers we sell fit a niche in the market for operators need 2-5 acres of mowing production per hour and had 35-50 HP and want to spent less than $3000 for them new. This gives the smaller operator the mowing technology of a disc mower at an affordable price for the smaller operator. Larger drum mower models beyond 6.5' require large tractors and are heavier than the same size disc mowers. We recommend the disc mowers for 7' cuts and above because the disc mower technology is better suited for larger machines. CCM makes disc mowers here in the USA.
Loren
09-07-2005 18:26:46
 Re: HayDr. ?? in reply to Hay Dr, 09-07-2005 04:16:59
Thanks for the info.
