JD 350 elevator
Jack-Iowa
09-04-2005 08:16:15
Anyone have one that they are parting out or not working? I need the front gear on the pto side, it is 39 teethe and about 8-10 inches across.
thanks
Jack
Randy-IA
09-04-2005 18:08:38
 Re: JD 350 elevator in reply to Jack-Iowa, 09-04-2005 08:16:15
Hi Jack , Are you sure they aren't available from Deere ? I know that if it is it'll probably cost more than the elevator's worth . I have one and I like it , but I use it too . I haven't seen any others around these part's and I'm alway's rubbernecking for implement's ! I had to straighten the shaft that the pto drives when I got mine because they aren't available and I didn't want to drill all the holes needed in a piece of bar stock . I found out that the pto can be used on either side . And the bearings are off the shelf at any farm store . So you might try a farm store for the sprocket too . 1/2" shaft . Good luck ...Randy
Jack-Iowa
09-04-2005 18:33:44
 Re: JD 350 elevator in reply to Randy-IA, 09-04-2005 18:08:38
Thanks , JD does not carry anymore.I will find one somewhere.I got this for nothing, its just I like using it,comes in handy.
JMS/MN
09-05-2005 11:19:23
 Re: JD 350 elevator in reply to Jack-Iowa, 09-04-2005 18:33:44
Have your dealer run a reverse lookup using the part number. That will show if any other machines used the same part, so it may make your salvage yard search easier.
