OT
jc
09-03-2005 19:23:37
The positive post on the battery of my lawn mower broke off. I naturarly found out when it would not start. I thought I could jump start it and it would run like an automobile. It did not. The machine has a Honda engine. Why will this engine not run from it own electrical generation??
old
09-03-2005 19:52:22
 Re: OT in reply to jc, 09-03-2005 19:23:37
A lot of them will also burn up the alternator if you try to run them that way. They use the battery to help keep it regulated some how.
RobN
09-03-2005 19:33:52
The alternator may need power to the armature (thru the ignition switch & battery) in order for it to generate current and supply the ignition.
bubba 2
09-03-2005 19:29:37
Depending upon the type of alternator, some must have a source of current to excite the alternator.The early alternators used on brand new 1969 and up 4020s had a resistor on the alternators so they could be run without filling and installing the batteries.
