469 NEW HOLLAND HAYBINE
DENNY HAWK
09-03-2005 06:05:35
OUR NH HAYBINE WILL PLUG ON THE RIGHT SIDE AFTER A SHORT PERIOD OF USE =I CANNOT CURE IT EVEN WITH NEW KNIVES AND GUARDS .HAY APPEARS TO BACK UP ON THE RIGHT SIDE SHIELD AND WILL GET IN BETWEEN THE LOWER ROLLER AND THE BAR AHEAD OF IT AND WILL STOP THE MACHINE.SHIELD IS ROUGH BUT NOT THAT BAD IN MY OPINION --SAME HAS THE LEFT SIDE--HAY APPEARS TO BE CUT AND CONDITIONED--HELP=REEL TEETH ARE NOT THE BEST ON THAT SIDE-ONE BAR IS MISSING 3-4 TEETH==COULD THAT DO IT --THANKS FOR YOUR HELP==
DENNY HAWK
09-10-2005 13:29:55
 Re: 469 NEW HOLLAND HAYBINE in reply to DENNY HAWK, 09-03-2005 06:05:35
COME ON BOYS YOUR SLIPPING HERE==I NEED SOME HELP
09.10.05
Our Farmer
09-03-2005 06:35:50
First thing comes to mind are the last teeth on the cutter bar. There is a double tooth, one big and one small, that helps with plugging a lot. Other thing is the bar that goes out ahead of the reel. Not sure what it's called, but it knocks the tall grass down to keep it from winding up between the shield and the end of the reel. I fought this battle myself for a while. Finally bent a piece of conduit into an L shape and screwed it into place with sheet metal screws. Haven't had the problem since.
