Need a knotter for Ford baler
NHBalerman
09-01-2005 20:01:04
I need a knotter frame for a Ford baler, I heard that there is a baler junked out close to Nachogdoches but I haven't had a chance to go and check it out. I was wondering if someone might have one that they would sell me cheap. I am not sure yet if the older Ford baler knotter is the same as the 542,need to check in some of these books and find out. Thanks
Garry_TX
09-02-2005 22:54:55
 Re: Need a knotter for Ford baler in reply to NHBalerman, 09-01-2005 20:01:04
There was a 542 on the north side of 324 (Cushing Hyw) about 5 miles or so from Cushing on the Nac side (259) [a couple/3 years ago] - don't know if it is still there or not.
Baler was complete (at the time)& appeared to be in working order, 'except' it had , had a 'serious' run-in with a tree right in the middle of the pickup reel.
Owner wasn't home, & wife wasn't real clear about whether it was for sale at the time or not - only that it had been 'parked' for the last time! (apparently the baler wasn't working just right & he was wanting a round baler, anyway!!)
Haven't made it back by there, the last year or so to see if it is still there, or not.
Know of a 532 in Lufkin that is also parked & rusting to death, but is/was definately 'not for sale' the last I inquired about it----can get ya a name & (maybe) a ph number for it if ya want to try your luck at getting it.
Garry
NHBalerman
09-03-2005 19:20:40
 Re: Need a knotter for Ford baler in reply to Garry_TX, 09-02-2005 22:54:55
Thanks Garry, I am going to try and get by there and check on that baler at Cushing, I live over here in Carthage. But until then I am going to see what Errin has. Thanks
Garry_TX
09-04-2005 09:44:36
 Directions correction in reply to NHBalerman, 09-03-2005 19:20:40
NHBalerman,
Correcting myself -- Cushing Hyw # is 204, not 324.
Can't find my old 'notes', but best I can figure from a map, between Humble Camp Rd. on Trawick/259 side & Dalmont Rd. on Oak Flat/Cushing side. On north side of hyw 204, Look for a (brownish)brick house/wood trim with concrete drive, old implements scattered on 1 - 2 acre fenced area, immediately joining the front yard to the west. Several trees/bushes obstructing view of equipment.
Can't say for sure that the 542 is still there or not as its been well over a year since the last time I was by there.
Garry
Errin OH
09-02-2005 06:28:54
What model and just what do you need. Have a spare I4-80 (model 250) red baler. Parts are used but if you just need a frame or something like that I may be able to help.
NHBalerman
09-02-2005 09:22:30
 Re: Need a knotter for Ford baler in reply to Errin OH, 09-02-2005 06:28:54
Errin All I need is the knotter frame for a 542 baler,I will try to check and see if it is the same knotter as the 250. Let me know if you can help and how much. Thanks
RickB
09-02-2005 17:31:58
 Re: Need a knotter for Ford baler in reply to NHBalerman, 09-02-2005 09:22:30
7500751 knotter frame used on 14-80 sn 5843 and up looks to be the same as used on the 532/542 balers. Prior to 14-80 sn 5843 is different.
Errin OH
09-02-2005 21:07:50
 Re: Need a knotter for Ford baler in reply to RickB, 09-02-2005 17:31:58
Well if that be the case I might just have what you need. Ping me. errinh22(at)aol(dot)com
