Speed to run Ford 501 mower
Jackelantern
09-01-2005 18:41:11
Can someone tell me how fast the knife should be moving on a Ford 501 sickle mower? I grew up using the horse drawn IHC's which we always thought ran too slow. Now the 501 mower blade running on a Farmall H chugging along in 3rd or 4th seems to run way too fast,ie. going through quite a few pitman sticks. I am not sure whether I have the 10" or 12" pulley version, I think the 12" one.
Dan6152
09-02-2005 15:41:55
 Re: Speed to run Ford 501 mower in reply to Jackelantern, 09-01-2005 18:41:11
i agree wtih other posters..
ive a ford 515.. ive looked at 501 manual..
to cross reference ive a fordson super here
ive tried a few things setting up the mower for the coming hay season here.. cutting weeeds
with it.. i just putt around in 1st low and 2nd
and are mindful of pto speed,,
not to fast.. also i had to find the right tilt forward of cutting bar.. to keep it clear..
in heavey going can get clogged.. and i wasnt cuting a tall standing crop was leafy weeeds..in manual said at best could do 7 acres an hour or about 9 miles per hour,,
and t ome that would be at best and under optimum conditions,,i think my tractor has a hi speed gear box is too fast for most things,,like that..
if im hoeing i only use 1 low..
but im partial to having the pto go fast when hoeing,,too really turn the soil ..
i used a slasher other day you ppl may call it a brush hogg to mow weeds be fore the flower n set seeeds.. in an open area i could go in 2nd low..
but in heavy going 1 low.. even on the road going to nieghbours i find 3 low best to travel on
we got dirt road.. in 3 high tractor goes all over the road,,..and 2 high slower than 3 low,,
Dan
ChrisLSD
09-02-2005 04:39:16
I am not sure which size pulley I have on my 501 but I was always running mine too slow - it works much better and doesn"t chatter near as much if I am going faster
Tom in TN
09-01-2005 20:56:20
Jack,
I use a Ford 501 with my Ford 2000 tractor to put up about 20 acres of hay twice each year. My Operators manual specifies that the recommended PTO speed for a 12" sheave is 500 RPM with a maximum speed of 580 RPM. I think this is going to be the biggest factor as far as knife speed is concerned. I haven't broken a pitman arm in about five years. The last one I broke was my own fault when I allowed the bar to dig into a side hill.
So, having said all of that, I think that the best approach would be for you to try to determine your PTO speed at various engine RPMs and then go from there.
Good luck,
Tom in TN
Jackelantern
09-02-2005 18:56:15
 Re: Speed to run Ford 501 mower in reply to Tom in TN, 09-01-2005 20:56:20
It does seem to cut better at a higher speed. I am cutting some rough terrain with plenty of rocks. A few too many and a bit too rough on a bush hog. Most of the time the bar jumps up and over a rock. I think I have been letting the pitman get hit by them as I mow. I'm cutting a bit higher this time. Thanks...
