I have found and looked at 2 balers locally and am looking to buy one for next year. I am not a bigtime hay farmer or anything just a hobby farmer who has around 35 acres to bale next year.I realize these are very old machines and my budget isn't large... That said... I am looking for help or opinions as to which of these you all might recommend. I have read in the archives on both and I am stumped as to which might be better. Here is what I have found on the two I have seen. The NH 66 This unit is sitting on a friends farm and hasn't been used in over 2 years I would guess. There is no grease on the knotter gears any longer and the chute shows signs of rust. It is free as I have turned the flywheels over and it moved and operated fine. Just no maintenance done recently. The owner has no idea if it still works but It worked when put away etc. Overall it really wasn't in bad shape but I didn't like that it was out in the weather. He is asking $200 JD 14T This is on a farm that the gentleman is turning 92 and has decided to stop farming! no joke. So he is selling off his equipment. This unit is well greased and has been run this spring. It was always kept inside and is in good overall shape. The knive looks sharp in there. The owner said he did have a problem with a knotter not working quite right and he THINKS he replaced it awhile back but said it probably needs some further adjusting. I have never used a JD baler and am very unfamiliar with those knotters and setup. Overall though I would say in better physical shape possibly. He is asking $400 OBO I will be baling with an old farmall M. Small time guy hoping to benefit from all this good info! Thanks All. Pro's Con's or open comments more than welcome. Basically just want something that'll do the job effeciently and keep me from going broke or losing my hay in the field!
