Ford 515 Mower
Joe Kelly
09-01-2005 14:56:43
I need the 8" flat idler wheel for a Ford 515 mower. The bearing keepers came out, ruined the bearing and wallowed out the bearing opening in the idler wheel.
This item is no longer available from New Holland/Ford. Any help in finding a good used (or a new) one would be appreciated.
Thanks,
Joe
dan6152
09-02-2005 15:52:07
 Re: Ford 515 Mower in reply to Joe Kelly, 09-01-2005 14:56:43
Hi Joe im in west oz i got i 515 mower i inherited
i plan to do hay with it this year,,
i got some pics from manual..online.
andlike you i asked new holland to no avail,,
i been learning and testing mower to get it ready been a learning curve for me,
ive learned a bit from online forums..
not just here..
got a wrecker yard just down the road here
they got acres of old stuf there.. but so close yet so far i can buy stuff online cheap n they charge sometimes.
ie power steering for a fordson... they want $1100.. online $100...
so i but carefully here..
what are you after ill go look at what they got..
Dan ps and if you got a manual for a 515 i got putter soft ware you can make it to a pdf file to post,,
DAN
Jeff McBride
02-18-2006 09:41:58
 Re: Ford 515 Mower in reply to dan6152, 09-02-2005 15:52:07
Did you get the part you needed? I have a 515 mower that has been parted out maybe I can help.
Joe Kelly
09-07-2005 08:33:00
Thanks for the note Dan and offer of assistance. I do have a manual for my 515 mower.
I have not been able to find a new or used replacement for the idler wheel.
The bearing in the center of the 8 inch flat idler wheel is still available. I found a machine shop that is going to attempt to rebuild the center of the idler, press the new bearing in and then use stainless steel washers welded in place to hold the bearing in.
It is supposed to be ready late tomorrow. We will see if it works. If it is not absolutely balanced it will just come apart again.
Thanks again.
Joe
