Haying Blues!
N. TX Tim
08-31-2005 20:51:56
In reference to my previous post about my NH 415 discbine with the cutterhead problems...I bought it used last summer and if I have cut 100 acres it would surprise me. It does look like someone has been inside this area of my discbine before...makes me wonder if someone did some sort of quick fix to haul it to the dealers to trade off. If so, I wonder how some people sleep at night.
Additionally, this discbine is hooked to my JD 4430 that I made numerous posts on the JD board about weak hydraulics after the fluid warmed up. At the end of my last cutting, the hydraulics finally went completely south and it ended up being the 2 speed. Well, $2900 later, the tractor shifts great and is usable, but I still have weak hydraulics...so seems like the 2 speed was an additional problem, and it appears that the main pump is in need of replacement as well.
I was a least grateful the the 4430 was useable...until today when I pulled the discbine up to the shop to dismantle it...and I notice antifreeze all over the place...now I have a radiator leak.
I am already a couple weeks late cutting my hay and a couple small fields I do for friends/neighbors...and now all these problems. It appears that I have one POS pulling another POS!!
Am seriously thinking about fixing them both and trading for an newer 80ish hp tractor and a new disc mower. What do you reccommend as far a tractors and disc mowers. Have heard Vermeer, NI, and Vicon mentioned a lot on this board, but don't know which is better...also, cannot find a website for Vicon to get information. Any suggestions welcome!
Thanks,
Tim
MNfarmer
09-02-2005 05:32:55
 Re: Haying Blues! in reply to N. TX Tim, 08-31-2005 20:51:56
Tim, this spring I bought a 3year old JD 926 discbine and I really like it. I've never ran a NH discbine but one thing i like better in the deere is that they have bigger discs so that means fewer of them. the deere also doesn't have the worm gear and shaft like the NH. Gears all the way across. I'm not saying there is anything wrong with the NH, I just like my deere. I pulled it all summer at 7 1/2 MPH with my 185 Allis Chalmers with no problem. The 185 in the last two years has been way more trouble free than our deere tractors. Just my opinions, but i hope this helps you out.
Fern(Mi)
09-02-2005 04:43:15
Tim:
As one of a handcrapped crew working this farm we find our old 1850 Oliver�s (90 hp class Perkins engines) easy to work on. Parts readily available and reasonable priced. No splitting the tractors for most repairs.
We�ve two old Hesston hay conditioners (500 & 1400) simple in design, easily repaired, in use today. The last one new (third (1440)) this Spring is so far trouble free. Not nearly as many machinery parts in it to go wrong as some other makes.
We are using an old 605 Vermeer bailer since new. It has always been easily fixed when needed. Have new, couple years ago, 454 Vermeer haylage bailer, tough machine.
We have an Anderson bale wrapper for the haylage system. Good engine location for service, tune-up, or repair. An easily serviced machine.
Yeah, I know, Tim. I told you more than you wanted to know. Just telling you as many physical inconveniences we have around here we look the tools over carefully from having used and repaired the old tools experience behind us, we ask ourselves, can we maintain and use the new ones in the future. This is a DIY farm. Fernan in Shorthorn country.
kyhayman
09-01-2005 12:50:09
I'm real partial to blue, mid 70's to early 90's 76/77 series Fords and NI discmowers or discbines. Affordable parts, simple designs, easy to work on, and almost bullet proof.
dorset farmer
09-01-2005 06:53:07
I haven't heard specific complaints about any brand. I have a New Holland 615, and have been extremely pleased- especially how well it floats over our rough terrain without scalping. Mike
Luke S
09-02-2005 09:56:35
 Re: Haying Blues! in reply to dorset farmer, 09-01-2005 06:53:07
How big is a NH 615? I have a Vicon CM247 7'10" cut and wish I'd a gottena 9'2". Tried to pull it with my 42hp Kubota and it was a little heavy, but waaaaa yyyyy to small for my monster 108 hp Oliver 1955.
