Fixing Link Chain
Iowa Jim
08-31-2005 19:50:30
Ok, I am sure my grandfathers are turning over in their graves over this question!!!
I forgto how to fix a detachable likk steel chain. I have replacement links for my hay elevator, but I can not for the life of me remember how to get them put on. Must be too many years in college.
Jim
JMS/MN
09-01-2005 13:14:51
 Re: Fixing Link Chain in reply to Iowa Jim, 08-31-2005 19:50:30
Like riverbend says- you bend the chain. You bend the chain in the opposite direction that it goes around the sprocket. Curl it back, and it is obvious that you simply drive one link sideways out of the other. The cast iron thing- called a chain detacher, available in any good farm store, is a good buy- but you can do the same thing with a cold chisel and hard iron underneath it. Or clamp the chain in a vise, curl it backwards, and drive the loose link out with a hammer.
Nebraska Cowman
09-01-2005 04:02:02
What? They don't teach detachable steel chain in College? What kind of rinkydink school is that?
BobMo
08-31-2005 20:48:17
Look (compare orientation ) at the chain off your equipment, set the chain on edge and drive (tap) the new link into the slot at the end of the link. Bring back memories? Hope you can understand my jibberish. Good luck.
riverbend
08-31-2005 20:41:57
Bend the links to line up the 'side plate' with the slot and drive them to the side. A chain anvil helps.
