Plow
Paul Samson
12-26-1999 07:48:06
Should I store my plow inside or outside ?
Paul Fox
12-26-1999 08:58:33
 Re: Plow in reply to Paul Samson , 12-26-1999 07:48:06
I'm assuming we're talking about a moldboard plow here. It is always better to store equipment inside if you have the room. A plow has relatively few parts that can be seriously damaged by the weather, so it is usually one of the last things on the list when you have limited storage.
Inside or out, use the plow enough to scour the bottoms (shine 'em up) and then put a protective coating on them. Also, if it has a hydraulic lift, either remove the ram or store it retracted to keep the chrome surface on the rod protected.
Red Man
12-26-1999 18:31:03
 Re: Re: Plow in reply to Paul Fox, 12-26-1999 08:58:33
If I store one outside, I paint the moldboards, points, and landslides and coulters with black paint.
