3 point hitch standard dimensions
PaMike
08-30-2005 09:30:31
Does anyone have the standard dimensions for CAT II,CAT III three point hitches? I am looking for the implement dimensions, so that I can convert a forklift mast to 3 point hitch.
Thanks
rotten robert
08-30-2005 18:49:43
 Re: 3 point hitch standard dimensions in reply to PaMike, 08-30-2005 09:30:31
Check haere
http://www.ytmag.com/atrp/3points.htm
PaMike
08-31-2005 10:18:29
 Re: 3 point hitch standard dimensions in reply to rotten robert, 08-30-2005 18:49:43
I am looking for the dimensions of the implement part of the 3 point. Such as the vertical distance between the top link and the lift arms.
JMS/MN
08-30-2005 14:39:47
All 3ph specs are at www.asae.org.
PaMike
08-31-2005 10:16:31
 Re: 3 point hitch standard dimensions in reply to JMS/MN, 08-30-2005 14:39:47
I looked into that site, but you have to become a member (pay $$) to get any specs. Or did I miss something?
JMS/MN
09-01-2005 13:23:54
 Re: 3 point hitch standard dimensions in reply to PaMike, 08-31-2005 10:16:31
I've been listing that website for months- just checked after reading your message, and it is totally different. Used to be you could access all those dimensions you asked for- no fee involved, no nothing. I will be contacting them- American Society of Ag Engineers, to let them know how they've gone downhill by 'modernizing'.
Chad Franke
08-30-2005 12:13:30
What do you need? I have the ASAE standards on my desk, which do you want?
The attached link also has some of the dimensions.
Chad Franke
08-30-2005 12:14:01
 Re: 3 point hitch standard dimensions in reply to Chad Franke, 08-30-2005 12:13:30
Sorry,
Link
Link is here.
PaMike
08-30-2005 14:41:51
 Re: 3 point hitch standard dimensions in reply to Chad Franke, 08-30-2005 12:14:01
Thanks, thats helps me some. How about the height of the top link on the implement down to the lift arm pins. CAT II & III if you have them. Also, in the spec the lift arm spacing is from center to center of the arms when they are on the implement?
Thanks
Chad Franke
08-31-2005 12:54:52
 Re: 3 point hitch standard dimensions in reply to PaMike, 08-30-2005 14:41:51
The lift arm spacing is to the innermost retaining feature, usually an upright or the shoulder on the lift pin.
Cat II:
Lower hitch point spread: 32.38-32.5
Mast Height (distance vertically from lower to upper mount): 19
Cat III:
Lower hitch point spread: 37.94-38.06
Mast hieght: 22
Kent Haslam
09-20-2005 05:12:46
 Re: 3 point hitch standard dimensions in reply to Chad Franke, 08-31-2005 12:54:52
Could anyone help me with current info from the ASABE spec 217 regarding the 3-point implement mast heights (distance from the CENTER of the implement lift arm pins to the CENTER of the top link pin for Cats 1, 2 and 3)? I have accessed the ASABE website but am only permitted a summary view of the spec 217 without being a member. Thanks.
PaMike
09-01-2005 16:54:14
Thanks!!
That saved me a bunch of measuring and trial and error.
Allan in NE
08-30-2005 09:34:03
Left side of this page called "3-point specs".
Allan
