King pins on old JD running gear
WilMan
08-28-2005 19:35:59
I have an old JD running gear that was my Grandfathers that I am thinking about restoring. I know the king pins are froze solid in it. How hard will it be to find replacement bearings etc for this. Anybody have an exploded view of how everything comes apart?
Thanks for your help
Wil
Leroy
08-29-2005 06:24:52
 Re: King pins on old JD running gear in reply to WilMan, 08-28-2005 19:35:59
There was also the 902, 951,952, 963, 943 all rubber tired
WilMan
08-29-2005 05:47:53
Thanks for the responses. I will have to figure out what model number it is and go from there. It is on rubber with 6 bolt rims and has a hand crank winch on it that was used to raise the old wooden flare box that used to be on it. So maybe a 953? Will try to get some pictures and post them.
Thanks
Wil
big jt
08-30-2005 06:29:09
 Re: King pins on old JD running gear in reply to WilMan, 08-29-2005 05:47:53
6 bolt rims? 953 or 963.
Try mother deere. I know 7 or 8 years ago I was able to buy a new real axle stub so would guess you should be able to get what you need.
953 will have hubs with a cast iron screw on cap and will look longer than normal. 963 will have hubs that look like most other implements and will have a press in cap.
These are good old gears and there are LOTS of the 953's out there. They are still holding their value also. Around me you can't touch a usable 953 for less than $300.
jt
big jt
08-28-2005 22:58:44
Are you working on a 953 or a 802. The 953's were really built as a rubber tired gear. The tongue will flare out where it attached to the gear. 802's were mostly steel wheeled and if on rubber will probably have spoked wheels. 802 would originally had a wood tongue.
Now to the question. If it is a 953 (I doubt it) most of the parts are still available through deere.
If it is a 802 take the cap off the spindle (kingpin) and heat the casting the spindle runs in with a rosebud till it glows. Spray some sort of penetrating oil in the moving parts and start hammering on the steering arm. With a little patience things will work loose. Drop the spindle out to let the loose rust out and clean up a little. Put all back together hit with a grease gun and all will be right with the world. BE CAREFUL SOME PENETRATING OILS WILL FLAME UP WHEN DOING THIS I KNOW WD40 WILL. I have had real good luck with this method. Have done 2 or 3 and most were donated to local threshing show where the gears get abused so they will stand up after heating.
Make sure to head the warning about the flame up. This won't hurt the work you are doing but be cautious that it may happen.
hth
jt
edchainsaw
08-28-2005 21:32:24
you tried Deere??? I know it sounds silly but..
our old 953's bearing caps were still available...
