john deere 40 bale thrower
Andrew Gross
08-27-2005 11:39:02
I have had trouble getting my baler to kick the bales to the back of the wagon. I was wondering if there was any way to fix this.
Bill C
08-27-2005 14:12:06
 Re: john deere 40 bale thrower in reply to Andrew Gross, 08-27-2005 11:39:02
Hi, I had the same problem. I fix it by replacing the 2 drive belts to the hydrualic pump. Also check the idler for these belts. Bill
nicholas1836
08-27-2005 19:56:12
 Re: john deere 40 bale thrower in reply to Bill C, 08-27-2005 14:12:06
Make sure you keep the RPMs up and the hydraulic fluid topped off. I have a friend who thinks it is better to run everything a little slower but the kicker looses power.
You may also need a new cylinder.
Tim(nj)
08-28-2005 14:35:30
 Re: john deere 40 bale thrower in reply to nicholas1836, 08-27-2005 19:56:12
Also make sure the oil is clean and the filter is not plugged up before you go replacing expensive stuff.
Tim(nj)
08-28-2005 14:40:10
 Oh, and I just remembered in reply to Tim(nj), 08-28-2005 14:35:30
Make sure it has the right kind of oil in it. I don"t recall the JD spec, but if the oil is incorrect, it won"t throw right.
