Slightly O/T How long?
BobMo
08-26-2005 19:50:20
How long do you guys like to wait after a good rain before you cut hay? A day or two? A week? Low humidity?
If you cut over damp ground do you normally cut higher and turn it quicker?
kyhayman
08-27-2005 20:20:59
 Re: Slightly O/T How long? in reply to BobMo, 08-26-2005 19:50:20
If I'm not using the cab tractor as soon as it slacks off enough I wont get soaked to the skin, if I am, as sson as the sky gets the least bit light in the west and the lightning passes. I cut at the height for the crop, not the soil moisture. On wet ground I do like to tedder, maybe turn let some spots dry to keep it curing on the dryest ground.
Our Farmer
08-27-2005 06:38:00
For me, it depends on the likely length of the "window of opportunity" following the rain. If it appears it will be only a few days, I've been known to go out and cut even before the rain lets up. A little rain doesn't hurt much when the hay is green, only after it dries. The next morning I'll run a tedder over it, maybe again in the afternoon if it's a particularly good drying day.
If it looks like an extended stretch of good weather, I might wait a day, but remember, there's a reason the old saying is "make hay while the sun shines". Given the accuracy of today's weather forecasts, it's still sage advice.
mike brown
08-28-2005 05:49:32
 Re: Slightly O/T How long? in reply to Our Farmer, 08-27-2005 06:38:00
I learned a long time ago that rain doesn't hurt fresh cut hay so if it looks like a front with a big high coming in I cut before the rain. I set the haybine to make tight windrows wait for the weather to clear then tedd it out when the sun arrives . I think it puts me almost a day ahead of where I'd be if I wait to cut after the rain. If you use a discbine you can cut while it's still wet.
