kuhn disc conditioner
cowman2
08-24-2005 18:58:10
while mowing today the far right side of the cutting disc got very hot and started to seize any one had this experience or know what happened
BigMarv1085
08-26-2005 06:14:15
 Re: kuhn disc conditioner in reply to cowman2, 08-24-2005 18:58:10
I have found plastic baling twine, barb wire, and pieces of telephone wire wrapped under the turtles. Usually after my 1st round, I get off and put my hand on each turtle and see if one is hotter than the other, if it is, I take off that turtle and check.
JiminIA
08-25-2005 18:46:00
Sounds like a bearing, I have also heard of them binding up when there is too much oil in the gear box and it gets too hot...Jim
wolfman
08-25-2005 16:09:15
Had a NH 411 (which was a Kuhn); when one of the turtles got warm, it meant a bearing was going bad. I'd check about every hour or so for warmth. Also see if there is any wobble whatsoever; if so, it isn't safe to run it-those spin at 100mph or so! One day, one of the turtles split & half of it came out from under there; haal of a bang; took 20 minutes to find it-it was up in the next field; could have severed a tire or my head!
RickL
08-25-2005 15:37:35
Sounds like the previous post bearing gone.
Illinois Boy
08-25-2005 11:02:48
Without putting an eye on it, I'd say you've got a fried bearing.
