I H sickle bar Mower ID
`Ralph L
08-24-2005 13:01:46
I have run across a IH mower with a two-point hitch.It has the heavier hitch like a 560 takes and the decal on mower says U F28,if I'm reading it right.I need some info on it. Thanks Ralph
ihkovas
08-25-2005 00:14:16
 Re: I H sickle bar Mower ID in reply to `Ralph L, 08-24-2005 13:01:46
Ralph, the U-F28 was built from 1955 to 1957. The U stands for Utility,the F means Fasthitch(without the later "traction control") and the 28 was the series model. This mower was originally built for the IH 300U and was a narrow frame type mower,the lower pulley and pitman crank was off-set to the left. This same mower was built as the model 28 from 1957 to 1966 and had adaptor packages to fit other IH tractors.
