JD #44 plow tires
Philip Ralston
08-23-2005 18:35:09
I purcased a JD #44 plow with 16" wide beam. I need the 2 rubber tires that go on the steel spoke wheels. Where would I order them from? Both have different tread patterns. Plow is located in S.D.
Thank You for your help.
1940JDB
Leroy
08-23-2005 18:45:43
 Re: JD #44 plow tires in reply to Philip Ralston, 08-23-2005 18:35:09
For different tread paterns you must have a clutch lift plow, otherwise just plain implement tires and miller tire should have them, 6:00X16"
55 50
08-23-2005 18:54:34
 Re: JD #44 plow tires in reply to Leroy, 08-23-2005 18:45:43
Your local tire dealer should be able to get regular 600:16 implement tires. The traction type needed (if you have the manual lift) will be available from Miller Tire for about $75. www.millertire.com
