NH 277 Baler + Farmall M???
Mark (PA)
08-22-2005 09:41:47
Hello Folks
I am wondering if anyone can comment if they have used this combination (NH 277 + Farmall M) before or not?
According to what I have read this baler requires 30 HP. The Stock M is 30 HP. I have a pretty fresh rebuild done and I would think I am getting the full HP out of it. I don't know the weight of the 277 so I'm not sure if it would push my M around with a loaded wagon or not...
Obviously most concerned about if my M can handle this model baler.
Thanks for your help.
paul
08-23-2005 08:25:32
 Re: NH 277 Baler + Farmall M??? in reply to Mark (PA), 08-22-2005 09:41:47
The lack of a live pto would be a concern; with live pto you can make it work. without live pto you are really on the edge any time you get to a slug, can't let the clutch slip.
I run a 270 baler behind an IHC 300 - works great. With the TA & live pto, it's a great match. Power is enough - as long as I have enough gears to pick from & a live pto.
--->Paul
TP from Central PA
08-23-2005 06:52:18
Depends on what your baling..... .lighter grasses bale alot easier than high yeilding alfalfa. Also, I hope the M has had bigger sleeves and pistons installed at the last OH or you"ll be a tad short on power with the stock 248 powerplant IMO.
We often baled alfalfa/timothy mix with a NH 311 and pulled it with a M-TA that had a C281 engine..... ..The baler had a thrower and we pulled kicker wagons too. It was a bit slowing going in heavy hay, but it got the job done. Ran a NH 269 and NH 275 with it too.
