Haybine guards
Bret4207
08-21-2005 06:00:43
After catching the only rock in an 8 acre field with the guards on my NH 472 and bending a couple guards I noticed all the guards are well worn. I figure it's time to replace them. The ledger plates are dull and the cut is ragged. I understand there're different types available. Any opinion on long or short guards or which is better? I figure on doing the whole bar at once and that should help everything line up better too. I'm cutting grass mix, very scant alfafa.
randy ,k
08-23-2005 12:33:10
 Re: Haybine guards in reply to Bret4207, 08-21-2005 06:00:43
The short guards are rock guards and the long are good for cleared land with no rocks.I have found that the short plug up more on moss & mouse nests but is a must if your field has rocks.
Jimmy King
08-21-2005 08:37:32
Bret, I found over the years it was cost effective to pay the price at New Holland. They will not break as easy and you can straighten them by putting a pipe over the guard and pushing down. I always liked the long guards best some people like the short ones the best.
Jimmy King
08-21-2005 08:35:43
txgrn
08-21-2005 07:26:04
Have a local ag store that carries that kind of stuff. They have a cross ref for the different machines so you get the right guards. They are up to around $8 now so for a 9' mower you will drop a couple hundred bucks.
I have used short rounded ones and long skinny ones. Can't tell the difference but I think the short ones do better as the skid has a higher curve to it and should ride up over obstacles better.
Just like section blades, I think they are different because company x doesn't want to use the same parts as company y.
My 2c,
Mark
txgrn
08-21-2005 07:25:51
My 2c,
Mark
