Re ford sickle bar mower
Dan6152
08-18-2005 08:54:18
I got an old ford mower i want to find out
how to take blade from mower so i can sharpen them
dan6152
08-18-2005 21:36:33
 Re: Re ford sickle bar mower in reply to Dan6152, 08-18-2005 08:54:18
Ive found pic of mower on net
its a 515 with wobble box,,
i think i can even get a manual
online,,from the pics its definatley a 515
thanks i even found where i can get replacement blades..
Illinois Boy
08-18-2005 09:11:29
You can sharpen the teeth with the blade still on the cutter bar...
What's the model number of the mower?
Dan6152
08-18-2005 09:39:59
 Re: Re ford sickle bar mower in reply to Illinois Boy, 08-18-2005 09:11:29
im not exactly sure of model number ive
got to do further investigaion on the frame.
ive filed blades in situ.. some ppl locals have said hit it with the angle grinder.
angle grinders go too fast need t oget angle right,other wise blunt it, i got some flap discs
for grinder,i still want t oknow how to remove the blades so i can replace them if needed,
ill bee in touch more ok
Dan6152
08-18-2005 19:39:22
 Re: Re ford sickle bar mower in reply to Dan6152, 08-18-2005 09:39:59
This morning i used flapper disk on grinder one side was easy.. other was a bit difficult to get proper angle to sharpen it,..I"ll see how it cuts tomorrow.
Illinois Boy
08-18-2005 11:11:26
10-4...
Does it have a pitman arm or a wobble box?
dan6152
08-18-2005 19:32:04
 Re: Re ford sickle bar mower in reply to Illinois Boy, 08-18-2005 11:11:26
Im not sure what you mean by pittman arm
has an arm that goes to drawbar ,,
I also saw a plate with model and serial numbers
model number is 515 .
if you like ill try to post a picture of it for you..
paul
08-18-2005 20:07:29
 Re: Re ford sickle bar mower in reply to dan6152, 08-18-2005 19:32:04
A pitman stick is usually a wood stick that pushes the sickle back & forth. These generallyhave a ball & socket, there is a little lever you need to flip on the socket part and then the sickle will slide out towards the left - under the frame of the mower.
Wobble boxes will likely have a bolt to take out, & the sickle will again slide out under the frame of the mower.
--->Paul
dan6152
08-18-2005 20:33:17
 Re: Re ford sickle bar mower in reply to paul, 08-18-2005 20:07:29
I couldnt see a stick,,
looked to me like it was bolted in..
Had a ball with a bolt through it,,
on left hand drive side of blade..
thanks
DreamingGreen IN
08-25-2005 00:18:52
 Re: Re ford sickle bar mower in reply to dan6152, 08-18-2005 20:33:17
Remove the knife by unscrewing and removing that big bolt, then slide the knife out to the left. First pull the belt by hand so that the knife is as far to the right as it will go so that you can have full access to the bolt. When you replace the knife, make sure the bolt is tight (it sits in a bearing). Good luck.
