Oliver No. 312 Gang plow
Gary in Pa.
08-16-2005 15:04:51
I recently inherited an Oliver No.312 plow which I'd like to fix up and maybe restore. It's a hydraulic lift plow on rubber tires and the tires are bad. That's about all it needs. The furrow wheel is a 16" while the land wheel is a 15". I have the set up and operating manual and it doesn't refer to the tires at all. Does anyone know if the sizes are correct or should they both be 16" The 16" wheel looks to be original but I'm unsure of the 15" Thanks for your help.
Gary.
Leroy
08-17-2005 05:15:02
 Re: Oliver No. 312 Gang plow in reply to Gary in Pa., 08-16-2005 15:04:51
Are they bolt on wheels? If so could one have gone flat and he just grabed anouther wheel he had to get running again? Or are they hub specificate?
Gary in Pa
08-17-2005 17:37:22
 Re: Oliver No. 312 Gang plow in reply to Leroy, 08-17-2005 05:15:02
Yes they are bolt on. That's what I was thinking also. The wheel probably got changed in a rush to get the job done. We used to do that all the time to keep from being down for very long. I guess the correct wheel never got put back on.
