New pasture/ What to do?
Greg C
08-16-2005 14:23:56
I've got the chance to rent a new pasture for next year, good ground, only 4 miles from home, and cheap rent to boot. Now the problems, this ground has set idle all year and the weeds have taken over big time. I'm not sure how to tackle this one. I'm pretty sure I can start work on the land within the next month, to get it ready for spring planting. I'm wanting to put it in a orchard/alfalfa mix. Any advice would be greatly appreciated.
Thanks, Greg
Jerry D in NC
08-16-2005 19:46:53
 Re: New pasture/ What to do? in reply to Greg C, 08-16-2005 14:23:56
Not sure where you are located but I would consider the need to put in the alfalfa with the OG. I am in NC and the alfalfa has finally beat me. I have not broke even the last two years on establishing and maintaining several acres of pure alfalfa. I love the stuff but it is hard to grow "here". On rental land that I have a year to year lease on I would not invest the $100 and acre establishment cost for alfalfa and drop back to just OG. I can establish an acre of OG for $30 if I NoTill and make as much money on 2 cuttings as the 5 cuttings of Alfalfa with less effort. Chemical costs are lower as I can use cheap 2-4D on the pure grass in the spring as I spray nitrogen and take care of the weeds for les than $5 an acre. If the land is smooth then bush hog it, Roundup it and NoTill it. Let the OG have the fall to come up. Get the soil samples and follow the instructions. OG is 12 to 14% protein if you cut it at the right time and unless your wife is working the horses VERY hard will be more than enough feed value. I have found that I can sell good OG faster and easier than pure alfalfa.
Jerry/MT
08-16-2005 18:35:05
I don't know where you're located but if you normally have good moisture in the fall, I'd Round Up what you have now, let it die back,get a soil test, then till it up for a fall planting. Add lime per the soil test results. You usually don't get a lot of weeds in fall plantings and the days tend to be cooler so the transpiration rates are low and you don't get a burn out. Talk to your County extension agent regarding varieties and fertilizing.
GregC
08-16-2005 17:19:31
In rereading my post I see I was clear as mud. I'm wondering how to treat the ground this fall to make planting go better next spring.
This is just going to be hay ground, not a grazing pasture, should have been a little clearer on that.
I've got weeds in this thing that are 6-8 foot tall and everythings gone to seed already, so I'm not sure what to do. Should I plow it up now and then Round Up what comes up in a few weeks?
I'm wanting to replant this ground because there just isn't much left of it that's worth anything.
The Round Up ready alfalfa is out because I'm going to put in orchard with it, that seems to be what the "Horsey" people around here like. That and I have to feed my small herd too.(I've got 5 with one more on the way) My wife got tired of buying hay so I mentioned that we should just start making our own. Look at all the neat equipment I've been able to buy in the name of feeding them horses. We even named the farm Hayburner Acres, since it seems everything I do caters to them. But in the long run she gets what she wants and I get some of what I want, and in a marriage that's about as good as it's gonna get:)
paul
08-16-2005 21:55:45
 Re: New pasture/ What to do? in reply to GregC, 08-16-2005 17:19:31
I"d still try to get it planted this fall, in the next 2 weeks. Will be _much_ easier to control weeds. You will gain a whole cutting, probably 2, of hay if you plant this fall.
Since your weeds went to seed, you will be totally under all that weed pressure next spring. Hard to make good alfalfa under weeds. If you plant this fall, the weeds will die out with frost, and next spring the alfalfa will compete well with them. Three cuttings of alfalfa will control the weeds for the most part.
Don"t know why you put grass with the alfalfa, not done much around "here". But I hear others talk of it, so must have it"s place, if that is the custom where you are.
Plow it, spray it, notill it, whatever - any of those things work depending on the equipment you have.
Just, really would help yourself a _lot_ to plant it this fall if you have the clear land to do so now and there is no previous alfalfa growing there now.
As others say, hay/ pasture crops are a long-term investment, you need a lease for 5 years before investing the fert & seed & time to plant a hay crop.
--->Paul
KRUSS
08-16-2005 18:20:56
Lots of things will work. Make sure you have a fairly long term rental agreement or else you will be doing a lot of woek for somebody else.
GRJ
08-16-2005 16:28:26
First of all, alfalfa isn't very good for pasture in my experience. Orchard grass is great but it takes about three years to really get it going where you can pasture it. Cut hay off it for the first year or two.
Joe in IN
08-16-2005 14:55:15
I have done two plantings in the spring and 1 in the fall(planting a second this fall). I highly doubt I will do much spring planting anymore. Weeds took over for year one, year two on spring planting is ok butnot the first. Plus if you can still get it in this fall the yield next year is great(compared to planting in April). It is like the second year for the spring planted alfalfa...
If I do a spring planting anymore it will be Roundup ready Alfalfa...
FYI...I am still a novice at this haying thing...
Allan in NE
08-16-2005 16:03:15
 Re: New pasture/ What to do? in reply to Joe in IN, 08-16-2005 14:55:15
Hi Joe,
You're way ahead of me, 'cause I've never done this in the fall before. But, tomorrow morning, I'm gonna give 'er a robust go, 'cause I think the ground is just dry enough to work.
I'm gonna smack 'er once again with the disc to get a last weed/volunteer wheat kill, drill the alfalfa and then roll it with the packer. Does that sound like a plan?
Average frost here is the 10th of Sept.
Allan
Joe in IN
08-16-2005 20:45:09
 Re: New pasture/ What to do? in reply to Allan in NE, 08-16-2005 16:03:15
Same plan as mine. I Have disked wheat stubble/ lambquarter once. As long at it is dry enough this weekend, it gets disked again, drilled and packed. Same as you.
Someone mentioned removing the tubes to let the seed fall to the ground. You doing this??
FYI, I had an acre get drowned last summer so I replanted in the fall. I couldn't tell the difference between that and the prior springs planting by first cutting this year...
Allan in NE
08-16-2005 21:21:41
 Re: New pasture/ What to do? in reply to Joe in IN, 08-16-2005 20:45:09
Yes Sir,
Never could stand the look of alfalfa in "rows". I take the tubes clear off.
Allan
paul
08-16-2005 14:44:16
Any alfalfa growing in it now?
Then for best results, you must kill the alfalfa & let it sit for 3 months of good growing weather before trying to replant alfalfa. Old established alfalfa plants are toxic to new alfalfa seedlings most of the time, and this effect will last in the soil for a time. Some say it doesn't matter, some say you need a different crop for a whole year, but mostly 3 months of seasonable weather & you are good to go.
Otherwise:
Spray glysophate (Roundup) to kill the peranual weeds like thistles, and you can typically plant about 40 days before first typical frost and get a great start on next year.
Or work & level the ground now, and plant next spring with an oats cover crop.
To plant, there are notill drills so you don't have to touch the ground after spraying; to plow, disk, harrow several times, spin the seed on, and harrow again. And many different plans in between. Which do you prefer, what do you have available?
--->Paul
caseyc
08-16-2005 16:41:48
 Re: New pasture/ What to do? in reply to paul, 08-16-2005 14:44:16
i'm pretty sure what allen plans on planting now was i wheat this year, no alfalfa. what he has plowed was in alfalfa and he's gonna let that sit till spring.
casey
caseyc
08-16-2005 16:43:00
 Re: New pasture/ What to do? in reply to caseyc, 08-16-2005 16:41:48
sorry, thought you were replying to allen. my bad!
