Memory Check: John Deere Drill
Allan in NE
08-15-2005 03:58:48
Mornin' Fellas,
I have an old John Deere model DR-A grain drill that I want to plant some alfalfa with.
The man that I bought it from says that he thinks it is putting down about 8 lbs per acre and he had these adjusters set at roughly the 3 1/2 to 3 3/4 mark.
The problem is that there were remains of old alfafa seed in the large tanks and I don't know exactly how he was using the drill; I suspect he was mixing the alfalfa in with another grass in the big tanks.
These are just the standard old "gear-fed" type seeders on the small grass box. I think John Deere used 'em on many of their drills.
Does anyone know about where I'd set these adjusters to get rougly 10 to 15 lbs per acre out of the little boxes? The documentation I have on the planter doesn't say a word about the smaller grass seeder and all I have to go on is my "somewhat lame" old memory of how they should "trickle out" during operation. :>(
Thanks for any help,
Allan
third party image
MidMiGene
08-15-2005 11:11:25
 Re: Memory Check: John Deere Drill in reply to Allan in NE, 08-15-2005 03:58:48
Allan,
Sorry about misspelling your name on the email.
Picture has been send to you. Hope it helps you. Gene
MidMiGene
08-15-2005 09:53:04
Allen, I have a JD 167B Grain Drill.
I went and took a photo of the (chart for drilling grass seeds per acre) located on the lid, inside of the small seed bins. It is a large file and I still can"t post photos on this site. If you send me your email address, I will gladly send it to you. It is a little bit blurry, but is readable. Gene
TGIN
08-15-2005 09:39:10
My manual says notch 2 will plant 7 lbs. per a. so 4 should get about 14 .
JMS/MN
08-15-2005 09:24:44
John 51 mentions slop in the adjustment handle- always very true. That's why you adjust in only one direction, ie always advance the control lever. If you need to go back, go back to zero and advance again to the new lower setting. As far as rate- fill the seeder, plant a few acres, measure how much it takes to refill. Hopefully the drill has a working acre meter. Oftentimes you need to tweak one seed box to match the other- they may not empty out at the same rate, even though the lever settings match. Spider webs and dirt can restrict flow, or a missing seal will let seed flow out the side, past the flute.
John51
08-15-2005 07:31:03
Allan, there is usually quite a bit of slop in the adjustment handle and where it points on the scale. Having said that, mine is set at 10 and it's putting on about 18 pounds of alfalfa. I'd guess it would be in the 12-15 pound range at about 8. The only way to know is to plant some. I always hate that. Too little and you have a poor stand and too much, with the price of seed, and you see money floating away.
John
RickL
08-15-2005 06:43:41
get you a bucket and measure off distance to get it really accurate,all the drill I have used the book is just rough start point anyway. catch the seed from couple units weigh it out and go from there. I use a marliss drill and I do use the large box as it will shut down completely, none of the other drills I had would do that in the large box be it gp,jd or Ih.
RickL
08-15-2005 06:43:26
