slip clutch hub for ford brush hog
graygander
08-12-2005 16:39:36
Hello,
I have an old ford 5' brush hog, been told its a 901 but don't know for sure. The slip clutch hub is wore out and it wobbles on the input shaft. I would like to fix this before it ruins the shaft. Does anyone have an idea where I might find one?...everytime I call the ford dealer for anything they say its N.L.A. Thanks
Galen
08-13-2005 06:17:41
 Re: slip clutch hub for ford brush hog in reply to graygander, 08-12-2005 16:39:36
TSC has them around here (SE Nebraska). My JD 5' hog had the same problem. I just removed the clutch all together and drilled for a shear pin. Works great and only cost $12 for a new knuckle on the driveshaft. I do run an ORC (overrunning clutch) on everything - even though I have live PTO.
Jerry/MT
08-13-2005 17:55:24
 Re: slip clutch hub for ford brush hog in reply to Galen, 08-13-2005 06:17:41
I'm just curious. Why do you run an ORC on everything? I've been thinking of doing it on my rotary cutter to save the independent PTO clutch.
Don-Wi
08-14-2005 07:58:58
 Re: slip clutch hub for ford brush hog in reply to Jerry/MT, 08-13-2005 17:55:24
We ran our massey 285 on the silage blower for a frew years when our Oliver 1600 just couldn't hack it anymore. After the first couple years, the pto brakes were shot and we had to send it in for repairs. I am just about done rebuilding the 1600 now, so we plan on putting that one on the blower again. Some tractors just don't hold up to blowers. my cousin runs a 285 on his blower, hasn't had problems yet. go figure. Donovan from Wisconsin
And yes, we do idle down before shutting down.
Galen
08-13-2005 19:57:39
I just figured it was extra insurance! The PTO takes a lot of beating, especially while hogging - thought the $45 I spent on an ORC is better than $$$$$ to fix a PTO.
RickB
08-13-2005 03:52:39
You can buy the slipclutch complete from Tisco somewhat reasonably IF you need the version for 1 3/8" spline on the gearbox input. I don't know of a source for the 1 1/8" but maybe you could bush the shaft up if you have the smaller 1 1/8" input.
