Sprayer Pump not working
Lou
08-11-2005 11:40:53
This is a PTO pump, tag on it says the Hanson Equipment Co. Beloit Ill. Was working great spraying liquid fertilizer, tank ran out, and would not work when I refilled. Any ideas would be greatly appreciated. Lou
haybud
08-14-2005 18:49:33
 Re: Sprayer Pump not working in reply to Lou, 08-11-2005 11:40:53
open the pump,clean and use a heavy wt.oil when you put it back .
no.2
08-12-2005 03:30:23
My son had nerely the same problem last week spraying round up. He usually doesn"t run the tank empty but he did this time. Seems he sucked some crude out of he tank and plugged the filter. He had checked the filter and cleaned it earlier that day and didn"t think to recheck it that quick.
Bill in NorthCentral PA
08-11-2005 19:22:56
I hook up a garden hose to the inlet and let it run throught the pump to the tank for a minute. Then shut the pump off and hook up the supply line (actually through a fitting as to not get caught up in the pump. Mine do the same thing as yours all the time.
Good Luck,
Bill
JMS/MN
08-11-2005 18:37:34
What type of pump- roller or centrifugal? Roller pumps are notorious for not being able to handle many products. Product eats up the rollers, depending what they are made of.
Ks-farmer
08-11-2005 12:19:44
pull the hose off of the pressure side and let a little run out, it probable got vapor locked and needs primed.
Lou
08-11-2005 12:31:18
 Re: Sprayer Pump not working in reply to Ks-farmer, 08-11-2005 12:19:44
Thanks KS but ive replaced the intake hose thought it might be sucking air,taken the exhaust hose off, pored water through it. You name it ,Im afraid it might have to be rebuildt, but I really dont know. Lou
farmermatt
08-11-2005 19:58:44
 Re: Sprayer Pump not working in reply to Lou, 08-11-2005 12:31:18
dont be afraid of a rebuild, roller pump kits ive seen are $20-$30 and centrifugal can be rebuilt with new impeller and all for $100. I would think the pump should have a drain plug, I would take that out until liquid runs out that would prime it. Assuming the pump is lower than the tank.
Lou
08-12-2005 09:18:18
 Re: Sprayer Pump not working in reply to farmermatt, 08-11-2005 19:58:44
I appreciate all the info does anyone know who handles parts or rebuild kits. Lou
no.2
08-12-2005 14:50:17
 Re: Sprayer Pump not working in reply to Lou, 08-12-2005 09:18:18
Tractor Supply handle some makes.
KRUSS
08-14-2005 13:28:41
 Re: Sprayer Pump not working in reply to no.2, 08-12-2005 14:50:17
If you have a cracked fitting on the intake side it will suck air and WILL NOT PRIME from right empty. Been there done that, tore the appropriate amount of hair out and enlarged my vocabulary over it.
