bush hog gear box
farmallbee
08-11-2005 10:17:38
I amy need a gear box or rebuild the one on it for a 6 foot lift type bush hog brand bush hog-How much are we talking about here?
mb farmall
08-11-2005 10:36:10
 Re: bush hog gear box in reply to farmallbee, 08-11-2005 10:17:38
What model of cutter is it? You also should have a tag on the gearbox with the actual number of the gearbox.Let me know and i should be able to help you.
cam76034
08-23-2005 11:54:55
 Re: bush hog gear box in reply to mb farmall, 08-11-2005 10:36:10
Well I know I've stripped out the gearbox on mine, I'll try to find the tag or number you're talking about, cause I have no idea what to replace it with. Does anybody know what they cost? 5' bush hog and almost looks like a homemade job.
farmallbee
08-11-2005 15:40:28
upon closer inspection and removal of the top plate-the oil seal is gone and the roller bearing must be replaced i believe all else is in good condition. So now I just have to do it.
Thanks
JF
farmallbee
08-11-2005 13:47:52
the bush hog website says it is part # 71282
farmallbee
08-11-2005 13:39:06
I will get it to you in a couple of hours. The reason i am concerned about the gearbox is that the cutter shakes when you use it and I just realized that the thing developed a leak and may be low on gear oil.
supergrumpy
08-11-2005 13:44:45
 Re: bush hog gear box in reply to farmallbee, 08-11-2005 13:39:06
did you hit anything recently?, I tangled with just the right sized stone and it tore big chunks out of my blades, machine vibrated pretty bad until I put new ones on
after heavy grinding, I weigh both blades on fish scale to make sure they are close
