NH Bale Chamber Tensioner - Where to get one?
Iowa Jim
08-11-2005 09:25:23
The threads on one of the bale chamber tensioners stripped and I need to replace it. I don't really want to pay for a new one from NH. Anyone know of where I could get one?
Jim
broker farmer
08-12-2005 06:19:15
 Re: NH Bale Chamber Tensioner - Where to get one? in reply to Iowa Jim, 08-11-2005 09:25:23
Same thing happened to my Massey 124 baler. Upon closer inspection, only the threads of the nuts had stripped. I simply ground down the nut, knocked it out and re-welded a new nut in place. Still working fine after about 3 years. Check your's closely.
Jimmy King
08-11-2005 11:47:22
Jim go to you auto parts store and get a threaded rod that size and cut the old threads off wield the new ones on I have seen several done this way.
Clyde B.
08-11-2005 11:19:42
When the threads stripped on my 67 NH baler I used the long nuts for threaded rod. I believe they were 5/8 coarse thread on mine and about 2 1/2 inches long. I just screwed them down on top of the tensioner to hold them in place, usually not all the thread is bad.
Rexalot
08-14-2005 10:56:17
 Re: NH Bale Chamber Tensioner - Where to get one? in reply to Clyde B., 08-11-2005 11:19:42
Thats what I did with my S67 when it decided to launch a chamber tension spring when the threads gave way. Luckly, nobody got hurt and most of the parts landed just in front of the tractor (saw the handle fly by.. and whoa..) I never did find my spring even after walking in circles around the baler in a 200 ft diameter(Guess it went to the moon) To fix mine I got a piece of all thread in the same diameter as the original, bolted it at the bottom with lock nuts/washers and then I reamed out the old stripped tension handle and welded a new nut onto it. It would have been a cleaner look to cut the old nut off. I was able to find springs of about the same # of coils/preload and length so I lucked out.
Quick fix, cheaper than NH parts.
