NH 68-Aligning needles
PaMike
08-10-2005 09:27:51
We had a crash with our 68, and we broke both needles. I fixed the problem, and I got two new needles. I bolted them in but when I go to turn the machine over the needles come up and hit the underside of the twine disks. I used the jack bolts to adjust the needles as far front as I can but I still cant get them front far enough to come up though. I have the manual and I am doing it as they say. The mount that the needles bolt to doesnt appear bent, but I dont really have any way of knowing where exactly the mount should be. Any ideas?
Steve from New Holland
08-11-2005 04:33:49
 Re: NH 68-Aligning needles in reply to PaMike, 08-10-2005 09:27:51
Hi Mike. If the needles cannot be adjusted high enough to clear the twine disc, then the needle yoke is definately bent to some degree. It doesn't take much of a bend at the mount to change the needles way out at the tip. Heat the needle yoke around the 2 ears where the needles are bolted fast and then have someone handy to put their foot down thru the bale chamber and push on the end of the needle. (Note: Bring the needles points part way up into the chamber). I have bent numerous needle yokes like this out in the field. This should fix you up. Steve
PaMike
08-11-2005 16:12:01
 Re: NH 68-Aligning needles in reply to Steve from New Holland, 08-11-2005 04:33:49
Thanks! I kinda figured I would have to do that, but I wanted reassured before I go bending something. Thanks again for all the NH insight you have.
Our Farmer
08-10-2005 15:15:50
The needles should come up and pass as close to the twine disks as possible without touching, like within 1/8" or so. The needles are adjusted using the mounting bolts.
PaMike
08-10-2005 16:57:33
 Re: NH 68-Aligning needles in reply to Our Farmer, 08-10-2005 15:15:50
yup, thats what I am trying to do, but I have it adjusted all the way out, and it still doesnt clear the twine disks. Makes me think something got bent in the collision.
