Koyker Loader-Good
pbutler
08-09-2005 05:41:07
I am looking at a Koyker 210 loader to put in my Massey 255. (50hp). Koyker through internet looking to be about $1,000-$1,500 cheaper than a Woods through the dealer.
Anybody have any experience with Koyker? Good loader?
txgrn
08-09-2005 18:50:04
 Re: Koyker Loader-Good in reply to pbutler, 08-09-2005 05:41:07
I have a 310 for my 80 hp tractor with hay spikes. Has the fast attach which is slick. It was delivered to my house.
Only problem I had was in installing it by myself and not knowing what I was doing.
There was a locking bolt for the rear part (slides into a grove in the front of the tractor and other grooves on both sides of the tractor then a bolt on each side secures it) that was supposed to be slack so that the loader would slide into the tractor bracket (then you tighten the bolt). I finally figured it out and things went well.
Have had it for going on 2 years now and zero problems. Cost just as much as a 30 year old JD 152 and it was new.....I didn't have to redo the cylinders and hoses like on the Deere.
I went to TSC and got a double acting Cross valve and hoses. Built a bracket so that the controls are even with the steering wheel and about 1 foot to the right. The color matched my JD Green perfectly.
Mark
pbutler
08-10-2005 04:29:05
 Re: Koyker Loader-Good in reply to txgrn, 08-09-2005 18:50:04
Thanks! I will probably order one soon, sounds like an install mistake I would have made too.
txgrn
08-09-2005 18:49:51
Mark
txgrn
08-09-2005 18:49:59
Mark
txgrn
08-09-2005 18:49:43
Mark
txgrn
08-09-2005 18:49:36
Mark
txgrn
08-09-2005 18:49:17
Mark
