273 twine knives
Tom 8N396936
08-08-2005 07:22:55
I am going to change the twine knives in my 273 baler. Will I need to make any other adjustments to the new knives or are they just a remove and replace?
thanks
tom
Brandon J. Love
08-08-2005 15:29:56
 Re: 273 twine knives in reply to Tom 8N396936, 08-08-2005 07:22:55
You should not have to make any adjustments. The original knives are riveted on the assembly. Take the horizontal bolt on the bottom side of the knotter assembly out. You will be able to lift both knotters up; take a die grinder (like a Dremel) and cut the rivets off. The knew knives will come with a shim and two #10 screws. Change them out and you will be in business. Good luck.
