to Steve from NH Tine bar 282
Hayfarmer
08-07-2005 11:26:25
I had a problem breaking the auxilliary drive shear pin usually when tine bar was in upper position going around top of the lh sprocket. You suggested looking at wear in chain again. Found most of the chain to be ok but the link on either side of where it pins to the tine bar were worn on the side that goes toward the sprocket, also were somewhat loose. Put in a better looking chan from a 280 parts baler I had. Just baled last night and seems that problem is solved. Broke one set of shear bolts and that was too much hay and pin broke with tine bar on the bottom. Thanks for the help anyway, wasnt looking in the wrong place I guess.
