Ford Mowing Machine
David (NY)
08-05-2005 16:05:14
I just bought a Ford mowing machine. Everything seems to be in good working condition. I'm wondering about what model it is and when it might have been made. There does not seem to be the traditional metal tag that is on other Ford implements. It is Ford red with "Ford" stenciled in white script leters. It has a 6' sickle bar, uses a wooden pitman(right term??), 3 pt hitch. Is there a source online to fine some pictures?
Tom in TN
08-05-2005 22:20:42
 Re: Ford Mowing Machine in reply to David (NY), 08-05-2005 16:05:14
David,
"It was the best of machines, it was the worst of machines." If you do have a 501, you'll want to be sure to obtain an Owner's Manual right away for it. I have one that I was ready to junk during the first year I had it. It was a bear to mount and clogged constantly when I was in the hay. I then got an Owner's manual and some advice from this forum.
I learned the steps needed and the sequence for doing them when I mounted and dis-mounted the machine. It now takes less than 5 minutes to mount or dis-mount it. I bought a new set of ledger plates and adjusted the clearance between them and the blade. I adjusted the swath board to make a clean gap in the hay at the end of the sickle bar. I made a minor adjustment to the angle of the bar and to the alignment of the blade when it was fully extended and fully retracted.
The machine works great now. I've used it for about 5 years on my 18 acre hay field doing at least two cuts per year. For the money invested, I couldn't ask for a better machine.
Good luck with yours.
Tom in TN
David (NY)
08-06-2005 03:16:59
 Re: Ford Mowing Machine in reply to Tom in TN, 08-05-2005 22:20:42
Wow, sounds like I've got some learning to do. Where can I get a manual (reprint or otherwise)?
John N Ky
08-06-2005 06:16:10
 Re: Ford Mowing Machine in reply to David (NY), 08-06-2005 03:16:59
Try here for some manual info on line
http://tinyurl.com/7rkhb
John N Ky
08-06-2005 06:15:29
Tom in TN
08-06-2005 06:00:20
David,
I hope that a particular guy will respond to this message. Some time ago, I copied my manual and sent it to a fella who had gotten my name through this forum. He subsequently scanned the manual into his computer and sent an image file back to me. It was really great. I sent the file to a couple of other guys for their use, but right now I can't remember where it is on my computer.
I'll look for it this weekend when I have a little more time. Maybe the guy who scanned the manual will see this note and respond also. If worse comes to worst, I'll copy my manual and mail it to you if want.
Tom in TN
David (NY)
08-06-2005 08:09:46
 Re: Ford Mowing Machine in reply to Tom in TN, 08-06-2005 06:00:20
Thanks, here's hoping. I found where the tag belongs (it's gone) and it most certainly a 501. Hoping to try it this afternoon.
Bill F
08-05-2005 21:43:01
Sounds like a Ford 501 with a 6' bar. I bought one this last month and like it. Search the implement photos and see what comes up under "Ford 501" and you should be able to tell if that's what your's is . . .
David (NY)
08-06-2005 03:14:09
 Re: Ford Mowing Machine in reply to Bill F, 08-05-2005 21:43:01
Thanks, I'm guessing it is a 501, similar to some ebay photos with a tag (mine has none - probably lost over the years). Any idea when they were made and what other mowers did Ford make?
Illinois Boy
08-06-2005 05:25:40
 Re: Ford Mowing Machine in reply to David (NY), 08-06-2005 03:14:09
I have a 515 - similar to the 501 but has a wobble gear box instead of a pitman arm.
