Need help for New Holland 850 baler
DavidW
08-04-2005 15:54:27
Tail gate when closed opens itself 2"-3"
Nebraska Cowman
08-07-2005 05:03:39
 Re: Need help for New Holland 850 baler in reply to DavidW, 08-04-2005 15:54:27
yup, like the other guys said. The 850 has no latch, you have to "power down" the gate. Hold the lever til it squeels. If the gate still comes up you'll have to rebuild the cylinders or maybe the valve on your tractor.
old
08-04-2005 18:43:03
cylinders probably need to be rebuilt since they are what holds the gate closed. the 850 doesn't have any other type of lock
larry h
08-04-2005 16:27:26
the tailgate cylindres are bypassing oil this is a common problem on the 850
davidw
08-04-2005 18:00:53
 Re: Need help for New Holland 850 baler in reply to larry h , 08-04-2005 16:27:26
can cylinders be repacked or need to be replaced
larry h
08-06-2005 10:15:17
 Re: Need help for New Holland 850 baler in reply to davidw, 08-04-2005 18:00:53
they can be repacked
kyhayman
08-04-2005 16:08:15
I dont recall if the 850 uses a hydraulic lock like and 851 or a manual lock like on the 846. On the 846 you have to hold the hydraulics and let them build up pressure to get the locks down on some tractors. On the 851, any leak off in the baler or tractor can release the valve and allow the tailgate to creep.
Allan in NE
08-04-2005 17:09:36
 Re: Need help for New Holland 850 baler in reply to kyhayman, 08-04-2005 16:08:15
Just thought of something,
'Spose he's not holding the hydraulic lever until the lock indicator trips?
Dunno,
Allan
kyhayman
08-04-2005 19:28:17
 Re: Need help for New Holland 850 baler in reply to Allan in NE, 08-04-2005 17:09:36
I did that more than once, tailgate banged closed and away I went. 846 I had didnt have an indicator, had to listen for the engine to bog down a little to make sure it built up pressure.
Allan in NE
08-04-2005 16:05:19
Dave,
Either the tailgate locks are not working properly or are out of adjustment.
Allan
Larry in Pa.
08-04-2005 18:13:18
 Re: Need help for New Holland 850 baler in reply to Allan in NE, 08-04-2005 16:05:19
If Your tractor has a "Float" position (for front loader contol) on the hydralic control and you push the control lever beyond "down" into "Float" it can release the tail gate. If you have dual outlets use the one without "float"
