Seed Drill Questions
Rod in Smiths F
08-01-2005 14:35:48
I'm new at growing things, but the garden is doing very well and I'm looking to branch out. I ploughed up the old garden plot, about 80 by 50' and worked it with my dad's old tractor-drawn disk.
I want to sow the little plot to oats to try out my dad's old horse-drawn seed drill. I can modify the tongue to fit the Ferguson TEA20, but I don't know anything about seeding.
How much oats should I get, and what tricks do I need to know not to make a mess?
The purpose of the oats is to provide a mulch cover for next year's plantings.
Thanks,
Rod
Rod in Smiths Falls, ON,
08-05-2005 15:30:30
 Seeding a garden plot to oats in reply to Rod in Smiths Falls, ON, , 08-01-2005 14:35:48
Thank you for the quality responses collected over the last week. I'll print them and act accordingly. Next time I'm by the drill I'll check its brand and model.
I have a few pieces of 5 X 5 ash around, so chances are I can make an improvised, short tongue to replace the long one and not ruin the implement for equine use.
"8 lb. double-cleaned feed oats, six seeds per footprint, overlap two rows, oats know what to do."
Uh, I guess you can't back up a seed drill to get into a corner. If I work out a pattern with the drag which allows me to cover the plot without getting stuck in a corner, I could seed to the same pattern with minor overlaps, I suppose. The Fergie will turn pretty short.
I put twelve bucket-loads of old horse manure on the plot today and disked it in. Next stop will be to talk to the seed guy on the corner of the farm.
riverbend
08-02-2005 19:50:34
 Re: Seed Drill Questions in reply to Rod in Smiths Falls, ON, , 08-01-2005 14:35:48
If your Dad's drill is in good condition, don't make any modifications that you can not undo later, i.e. cut the pole off, etc.
It will be hard to make a mess. The oats will know what to do. The drill probably has a setting for oats. 2 bushels or 8 pecks per acre is a pretty typical rate. Oats are cheap, get some extra. If you try to get exactly enough, the seed will pile up on the flat areas between the seed cups, and the drill will quit planting before you run out of seed.
The drill will not plant right up to the wheel track. You will have to run the wheel over the first or second 'row' to get complete coverage. Planting half the rate going in two different directions will help cover any gaps that you might have.
You might consider planting some field peas after the oats(at the same rate as the oats). They will also winter kill and fix a little nitrogen for next year's garden.
ejr-IA.
08-02-2005 18:34:26
Back to the good old days 6 seeds to a horse track.
justplainjim
08-01-2005 18:20:05
another thought...
I know you want to use your dad's drill and I applaud your efforts but...
If you fall way behind (as I often do), you can broadcast seed a plot this size with a hand cranked Cyclone seeder, then harrow with the Fergie to cover the seed. It'll work.
cheers,
justplainjim
08-01-2005 18:08:58
Rod, one acre is 43560 square feet so you have approx one tenth acre. Oats weigh 34 pounds per bushel. At a seeding rate of two bushels per acre (68 pounds per acre), you will require approx 6.8 pounds of oats to seed your plot. Your local horsey supply place, coop etc should have "double cleaned oats" or some such which people feed to their horses. It's not 'certified' seed of a named variety etc but the weed seeds have been removed and it'll work just fine as a cover crop/mulch plus you will not have a leftover bag of treated seed unsuitable for animal feed. A 40 kg bag will run you $10 or $12 dollars. If you plant now, you will get good growth before freeze up and of course the oats will winter kill in beautiful Smith's Falls.
Now you are probably wondering how to calibrate your drill to seed two bushels per acre???
What make of drill?
How many runs?
Bret4207
08-01-2005 16:32:33
Stop by the local seed dealer and tell them what you want to do. You might want to go with buckwheat instead of oats or field peas and annual rye. Talk to your seedsman.
