Loader Information
Ganus Hilburn
07-31-2005 10:41:21
Loader mounted on 64 Model, 2000 gas. Decal on loader 679, Ford ID tag shows T9-425, Ser. #2722.
Ford/NH national publications can't identify, neither can the dealers i've talked with. Any help would be appreciated. Thanks
Leroy
08-01-2005 02:48:09
 Re: Loader Information in reply to Ganus Hilburn, 07-31-2005 10:41:21
What model 2000? Row crop or standard tread and if row crop wide or narrow front end? Each would take a different model loader.
Ganus Hilburn
08-01-2005 08:20:49
 Re: Loader Information in reply to Leroy, 08-01-2005 02:48:09
Tractor is a Model 21201, which according to I & T. would indicate ag or ind., wide front w/adj axle and 4 sp transmission w/pto. (Which checks out.) Tractor ser. #64748, apparently indicates late "64. The loader uses front mounted pump, heavy framework around front end, which appears to be from the factory. The loader frame serves as fluid reservoir. The spool valves are built into a solid casting, bolted to the frame, with the outlet coming through the frame. In other words, the valve body apparently just gasketed to the frame with the outlet pipe welded to the back of the frame. Thanks for any info since I"m hesitant to take the valves apart without any. The trouble appears to be in the lift valve as the dump valve works fine.
Jerry D in NC
08-01-2005 19:30:13
 Re: Loader Information in reply to Ganus Hilburn, 08-01-2005 08:20:49
I am by no means a loader expert but did try to look up the numbers you had in your post. I would imagine that you need to change the T to an I which was a "1" in Fords numbering scheme. Take a couple of pictures if you can and repost. A picture of that tag would be noce as well
Ganus Hilburn
08-03-2005 08:33:36
 Re: Loader Information in reply to Jerry D in NC, 08-01-2005 19:30:13
Thanks, Jerry. I filled in the numbers w/crayon, and it looks like an "I" without a good impression at the bottom. So, it seems we have Model I9-425, apparently made by Ford as the frame has the "Ford" script cast into the frame.
I'm not computer literate enough to do pictures, I'll have to wait until one of my children or grandchildren come, then I'll repost. Thanks again.
Ganus
