Dogde a Major bullet
Errin OH
07-30-2005 21:47:42
Seems nothing has gone right the last few weeks. Car in the second shop and still is not running right. Cub mower puked. Tire went flat on the Case. Beans to wet to spray. On and on. I lost a seal on the woble box on my JD mower about a week ago. Picked up new seals and proceded to put them in. The input seal went pretty easy and under I go to get the lower seal on the output shaft. Whats this. Metal flake lube. Gee's oh man Just what I need. Pull shaft, check bearings. Two bad, replaced all. The during reinstall discover, Staurday bout 5:00pm. as in, no parts till Monday, that the back side of the woble shaft has bad scoring and is junk. This is not going to be cheap. Since I didn't have much else to do with no parts and could wait to fork out a bunch of cash. I split open a spare woble box for the combine, just to see. Cases are completely different but the innards are the same. For the most, or I should say critical parts. It uses a little larger berings in the woble assembly, but all the case bearings, shafts, and such are the same. Swap out yoke and woble shaft, wall'a she's up and running. Even got my hay cut. Now I am going to bed before something go's wrong.
Night all.
txgrn
07-31-2005 06:23:17
 Re: Dogde a Major bullet in reply to Errin OH, 07-30-2005 21:47:42
There you have it; another case of "Never Give Up". Hearing the perseverence of others helps to keep us (me) going.
Glad you got her going even though at one point it seemed hopeless.
Thanks,
Mark
Randy-IA
07-31-2005 08:00:18
 Re: Dogde a Major bullet in reply to txgrn, 07-31-2005 06:23:17
Hi , I agree with what txgrn said ! Looks like that should start a couple of weeks of good luck ! ...Randy
txgrn
08-01-2005 05:00:36
 Re: Dogde a Major bullet in reply to Randy-IA, 07-31-2005 08:00:18
Yeahhhhh hh!
Jerry D in NC
07-31-2005 12:04:53
His good luck, Heck I m happy for me. What combine had a gear box set that would fit that 1209 so when I mine blows up I can find one.... LOL
