NI pull type mower ID and Tire size
Larry in wiscon
07-29-2005 14:52:29
I bought a New Idea pull type sickle bar mower. Where is the model number located and what size tires should be on it? This is a work in progress and i need to try and find a manual. Any ideas? Thanks for your time.
Jerry Coulter
08-02-2005 17:03:22
 Re: NI pull type mower ID and Tire size in reply to Larry in wisconsin, 07-29-2005 14:52:29
Nobody responds, so I'll jump in. We sold New Idea from our AC dealership years ago. They all had the wood pitman stick and were models 30, 30A, & 30B. If it was a hydraulic lift model, an H is tacked onto the model. As best I recall, the 30B had 15" tires, the older ones had 16". You either put used car tires on or bought new implement groove tires with it. My 30B has a ID plate riveted on top of the axle. I can't find any ID on my 30A. Differences are minor, most parts interchange. The 30B has a newer style PTO shaft with the tube guard on bearings while the 30A has a separate sheet metal guard which connects to the tractor PTO guard. The 30A also has a tool box built into the main casting which the 30B has not. I have the owners operators & parts manual for the 30B. Write back if I can help you otherwise.
