Cheap Disc Mower Dilemma - repairing
Joe in IN
07-29-2005 14:19:06
Found a JD 260 that has been cracked open and needs either a bearing or new gear( I would find out which one by talking to the right guy). $500 as is.
Is fixing a disc mower a rocket launch or something that a person of modest mechanical means could accomplish themselves?
bigJ
07-29-2005 18:19:15
 Re: Cheap Disc Mower Dilemma - repairing in reply to Joe in IN, 07-29-2005 14:19:06
When they have needed to be opened it is too late for the machine. If you want to buy one you can repair easily stick with a New Idea. They are simple. I have had a 260, bought new. It was a good machine. Ran it so much that I wore the skid plates out. I wore so many, so fast that I started welding cold roll rods for skid bars on the new skid plates so that they would last longer. Never had to put a bearing in or replace anything more than the skid plates and knives. But I would never think of opening one up. When I traded it, it needed a bearing. I traded for a Vermeer. Bad mistake. They are too heavy. Don't like them. Now I have an old New Idea that I bought used for $1500 and a JD 265. Good buys.
DR HAY
07-30-2005 06:21:11
 Re: Cheap Disc Mower Dilemma - repairing in reply to bigJ, 07-29-2005 18:19:15
I agree the steel top Vermeer mowers are too heavy. This is where the lawyers engineered the weight in the mowers for safety. The new style 30 series has a Kevlar curtain are much lighter. Look for the Hay Max disc mowers next season using the hex shaft drive Lely style cutterbar. Lower HP demands with a stronger & lighter 3 point design that is thousands of $$$ less than a Vermeer, New Idea, Kuhn, Krone,& John Deere
If some one is considering a used disc mower why not consider a NEW drum mower for about the same money. For less than $3000, you can have the new cutting technology of disc mower for close to half the price.
Jim in MO
08-01-2005 07:33:05
 Re: Cheap Disc Mower Dilemma - repairing in reply to DR HAY, 07-30-2005 06:21:11
And you can fix 'em right up since you make them.
Cliff Neubauer
07-29-2005 16:27:41
I would go for it, at least if you rebuild it you will know you have a good machine,if you just buy a used one the gear box could go out the first time you use it.
KEH
07-29-2005 16:00:59
Joe, Be sure gear box is OK. About $1000 if you have to replace the whole thing, no fun repairing either. I think $500 is enough to pay for a disc mower in need of repair. As other posts say, alot of labor involved in repair.
KEH
KEH
07-29-2005 15:55:27
KEH
caseyc
07-29-2005 15:09:50
bought my gehl cheap cause of a bad bearing. it was a job. you need two people at certain parts or a over head hoist. not a hard job, just takes time. the halves are heavy once you get it split.
casey
Illinois Boy
07-29-2005 14:30:14
Joe,
That's pretty cheap for a disc mower - even a broken one!
I've helped a guy down the road tear apart both a 9' NH and a 10' Vermeer to replace lower bearings on a couple of pots. (don't remember the model numbers)
Not hard to do mechanically, but time consuming and a little frustrating when you forget to put something back in and have to pull the thing completely back apart again. But... what isn't??
