Ford plow question
GLC
07-25-2005 11:39:25
I have a two bottom ford plow for my NAA. Should I use it with the anti-sway bars attached (like with my Bushhog?) Or, should I let the plow swing free behind the tractor and follow its own path?
Thanks.
James2
07-27-2005 08:54:04
 Re: Ford plow question in reply to GLC, 07-25-2005 11:39:25
The 20+ years I have plowed with a 3-point, we never used anti-sway bars. The plow will "seek" and follow the natural draft line. However, Allan's suggestion to "tighten things up" would probably be fine. Just be sure to leave some slop.
BEN in KS
07-25-2005 21:49:32
Have to agree with Alan. Most anything I use behind the 8N is used with at least one sway bar. When plowing, it is important to keep the plow and tractor tires in some sort of alignment. Just my .02 Ben
Allan in NE
07-25-2005 14:55:16
GLC,
The rule says that any ground implement should be able to "swing" and just follow the line of pull.
However, I can tell you that three point plows will drive ya nuts will all that slop and swingin' going on back there when you lift 'em and also if you are working on a slope.
I pin 'em up "fairly" tight; not totally rigid, but tight. Might not be right, but it sure lets me keep what little hair I have left. :>(
Allan
Steve (Magnolia, TX)
07-25-2005 12:27:23
I don't own a plow, so I'm not speaking from experience, but...
Everything that I've read/heard is to allow it to follow its own path (NO anti-sway bars).
HTH
Steve
