When to use swinging drawbar
Wild Bill
07-25-2005 10:29:56
I was wondering when you actually use the "swing" feature of a swinging drawbar?
mgb
07-26-2005 07:59:29
 Re: When to use swinging drawbar in reply to Wild Bill, 07-25-2005 10:29:56
Truth is-there are very few times when your drawbar should not swing free while in the field. However, when transporting equipment down the road it should ALWAYS be in the stationary mode.
One example of when to use the stationary drawbar would be if you were using the old-timey drawbar-pull-type planter. You wouldn't want it to swerve at all.
John A.
07-25-2005 19:56:19
Wild Bill, The only time we ran a swinging braw bar on our old Farmall M was when we were "Onewaying". Dad bought a brand new JD 8 ft cut Tiller series oneway in about 1968. This is the ones with all rubber car type tires and a stinger or coulter style rear furrow wheel. The dealer set it up to be pulled with a 8 to 10 in offset of the drawbar from center. This was in a regular pull. In transport mode then the drawbar was pinned up @ center.
Later,
John A.
jc
07-25-2005 15:21:25
When transporting balers and pulltyre combines to provide extra offset inaddition to the toung swing on the implement.
paul
07-25-2005 11:58:42
Implements without wheels, such as a drag (harrow), disc, etc. These implements do not lift when you turn, and the swinging drawbar makes turning _much_ easier.
Otherwise for hooking up implements it works well to be able to move the drawbar.
Sometimes a different position is needed, like raking with a siderake, or if you double-plant with a planter & want to offset the planter 7.5 inches or something, then you use a different position of the drawbar - pinning it sold, but offset.
Kinda didn"t think I really used it much until I got my 1720 NH without the swinging feature - sure miss it on there. I see it"s an option, but the cost - it isn"t even worth checking into it. Was thinking of looking at the pic & trying my welding skills.....
--->Paul
dej(JED)
07-25-2005 11:36:12
You use teh swimging draw bar when you have an off set piece of equipment like a mower with a cutter bar. When pulling an old drag type plow, etc.
Allan in NE
07-25-2005 11:31:56
When hooking up to an implement was the only time I've ever used the thing.
Allan
Allan in NE
07-25-2005 11:28:56
Allan
Txsprigger
07-25-2005 10:31:55
With a Farmall H, we use it when pulling drag type disc. Makes turning a helluva lot easier.
Wild Bill
07-25-2005 10:30:51
 drat...double post in reply to Wild Bill, 07-25-2005 10:29:56
Oh, I can't believe I just did the dreaded double post
Illinois Boy
07-25-2005 11:34:03
 Re: drat...double post in reply to Wild Bill, 07-25-2005 10:30:51
Don't woirry about it - Allan did the "double reply"...
Harley
07-25-2005 13:16:51
 Re: drat...double post in reply to Illinois Boy, 07-25-2005 11:34:03
The main place was hooking up something and when pulling a two bottom plow you had to swing it hard to starboard. With a three bottom it fit right in the center. Mostly for different pulled implements I guess. Harley
GRJ
07-25-2005 15:55:28
 Re: drat...double post in reply to Harley, 07-25-2005 13:16:51
Mostly for discing or harrowing.If you try to move it either way from center plowing your line of draft is incorrect.
