king kutter brush hog
ric
07-24-2005 16:22:00
hi i acquired a 5ft king kutter 3 pt brush hog with a tractor i purchased. the problem is the blades seem to hit the underside of the deck making for alot of clanking and banging. they dont hit hard just kind of nicks it in a few places anyone had one of these do this befor
marlowe
07-24-2005 18:43:56
 Re: king kutter brush hog in reply to ric, 07-24-2005 16:22:00
blades bent, deck bent , wrong blades to long or wrong shape, bearing out of gear box, or out of balance real bad
Chuck Davis
07-25-2005 04:07:37
 Re: king kutter brush hog in reply to marlowe, 07-24-2005 18:43:56
Have you checked the mounting bolts on the gearbox? Mine would vibrate loose after a few hours of use.Broken welds on gearbox mounting plate another problem i had. King-Kutters are not the most well made or engineered hogs on the market.I still own mine as a back-up but the Woods i bought used is twice the machine and has given me zero problems in 4 years of hard use.
Illinois Boy
07-25-2005 11:43:15
 Re: king kutter brush hog in reply to Chuck Davis, 07-25-2005 04:07:37
I'd check this problem out before using anymore. Something is definitely "out of line". Prior user may have hit something hard (tree stump, rock, etc.)and messed up the gearbox bearing, or the blades just may be loose.
One thing's for sure - you DO NOT want one of those blades coming off while you're using it.
