JD RWA disc
Randy-IA
07-23-2005 15:32:25
Hi again , Is this a good disc ? It doesn't look adjustable . I found it on the web and it's about an hour and a half from me . It has 17" disc's and is 14' wide . The 1755 shouldn't even know it's back there . I pulled a 12' AC disc with 14" disc's after I first started the tractor after the rebuild this spring and couldn't feel that one . Would or could you hook this up to a 3-point drawbar to set front to rear angle or aren't those hitches made for that kind of load ? Thanks. ...Randy
paul
07-23-2005 23:13:45
 Re: JD RWA disc in reply to Randy-IA, 07-23-2005 15:32:25
They are known for ridging a lot.
The front handle/ spring set is used for adjusting hitch height - see pic in the link:
Link
aspx?IWNO=451586&ImgID=1
Generally a tandem disk on wheels likes to tip over backwards if they are Green, & I would not want to pull one with a 3pt hitch as it will be rolling on the back gangs....
--->Paul
Indydirtfarmer
07-23-2005 15:55:36
They weren't known for their leveling abilities. They tend to "ridge". Also, they're about the worst ever as far as shaking their tail when towing at speeds above 20 MPH. Still in all, Deere sold THOUSANDS of 'em.
