What to use ...?
Randy-IA
07-23-2005 12:38:29
Hi , On a different problem on my acreage I have a slope in the hay field which washed just after I planted in the spring of 04 . It affected about 2.5-3.5 acres by cutting in about 300 feet from the end of the field . Only about 3-6 inches deep mostly but it makes it rough for the old haying machines . What would be the cheapest and easiest way for me to smooth it out ? I was thinking an old disc ? My other thought was a box blade with ripper teeth . The biggest problem is the one time use till the whole field is ready to be replanted in 4-5 years or more . At the bottom where it leveled out some it left all the sand so I would also like to incorporate all my well composted horse manure in that area while I'm at it and I have a LOT of that . That's only an area about 100' x 200' at the bottom . This end of the field is the least productive anyway because I got about 2/3rds of the crop off the other half of the field . Any suggestions ? Thanks ! ...Randy
RAW in IA
07-23-2005 15:20:21
 Re: What to use ...? in reply to Randy-IA, 07-23-2005 12:38:29
If you have an old tandem wheel disc and can run the rear gangs deeper (tilt it to the rear) straddle the ditch and it seems that should help and be the quickest way to smooth it out.
