Hay Tests
Tom48
07-22-2005 12:23:10
I had some late cut hay tested, It was mixed grass of timothy, fescue and orchard grass the results came back and the 3 major areas of CP, TDN and RFV were as follows CP 10.2, TDN 45 and RFV was 85. Is this decent hay?
Thanks
Tom in TN
07-23-2005 08:23:04
 Re: Hay Tests in reply to Tom48, 07-22-2005 12:23:10
Tom,
Where did you have your hay tested? I've been wanting to have some of mine tested, but I don't have any idea where to take it. What was the approximate cost for the testing?
Thanks for your advice.
Tom in TN
Illinois Boy
07-25-2005 06:48:49
 Re: Hay Tests in reply to Tom in TN, 07-23-2005 08:23:04
Try your local County Ag Agent - usually runs about 10 bucks per test.
kyhayman
07-22-2005 19:50:01
Looks good to me for mixed grass without legume. All depends on what you are feeding it to. It wont put 3# per day on steers, a little short on energy for spring calving cows and a little short on energy and protein for fall calving cows. It would maintain dry mares or geldings.
CP= crude protein percent TDN= percent measure of energy (not exactly but it works if used that way)
RFV= relative feed value where full bloom alfalfa = 100
